🎉Community Raffle - Win $25
Join and Win
Damping Definition in MotionView!
Ankush WUser: "Ankush W"
Altair Community Member
Updated by Ankush W
Hello All,
How do I define different damping coefficients in tension and compression [ meaning expansion & contraction] in motionview for a shock absorber ?
Please suggest!
1 - 2 of 21
    AnanthKUser: "AnanthK"
    Altair Employee
    Updated by AnanthK
    Hi Ankush - Please see the attached example as a reference to create your own. The damper force-velocity characteristic is modeled as a Curve entity. Important:
    1) Rebound (extension) is in 2nd quadrant and Jounce (compression) is in 1st quadrant.
    2) Make sure to change the SpringDamper entity on both left and right sides since non-linear components cannot also be defined as symmetric!
    OP
    Updated by Ankush W
    Thank you Ananth for your reply.
    I'll try applying the same in my model and check.
    Thank you again!
