🎉Community Raffle - Win $25
Join and Win
solidthinking Inspire 2014 comparison Hyperworks
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I have tree questions:
1. used solidThinking Inspire the tool  Batchmaster before it starts to analyze?
2. is solidThinking Inspire use the Element Qualiti Check, before it starts to analyze? Because when I start to analyze from the same Model in solidThinking Inspire and Hypermesh, the analyze from Hypermesh stopt by the Element Qualiti check because of a bug in the finite element.
But solidThinking Inspire finished the analze but it has the same bug in the finite element.
3. What is the price form solidThinking Inspire and Hyperworks for a small busines (One licens).
Best Regurds and thank you all.
1 - 2 of 21
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi,
    Please find below answers to your query.
    1.It uses Simlab for meshing in the backend when you submit run in Inspire.
    2.In Inspire we just provide element size for static and modal run / min member size for optimization.Simlab default take care of  element quality called stretch criteria for tetrahedral element (refer attached thumbnail )
       Inspire generated fem file if you import in Hypermesh and invoke one card PARAM checkel set to No , then Optistruct solver will run without error.
    Basically Inspire is a tool meant for Design Engineer who don't want to spend time for meshing/ quality check and do quick topology optimization, validation optimized part using static and modal analysis. Hence Simlab default take care of element quality based on geometry complexity.If part is having complex feature and simlab fails to generate mesh then you could use geometry cleanup option to overcome such complex feature for meshing.
    Hence in Inspire we have envoked some best default card for Optistruct solver for smooth run.You can cross check the same in Inspire generated  .fem file  (PARAM chekel Card use).
    3. If you want to use Inspire for commercial purpose please contact your region Hyperworks support.
    Regards
    Rahul R
    <?xml version="1.0" encoding="UTF-8"?>post-36845-0-04396300-1428652603_thumb.j
    Altair Employee
    OP
    Hallo Rahul,
    thanks for the answers.
    Regards
    Nick.p
