Hello all,
I think I have seen similar questions to this one, however I do not think there has been a clear answer. As most users do, I find very helpful to simplify my geometries within hypermesh by suppressing lines that are not needed or will create problems during the meshing process. Since our company uses more than one pre-processor (as most do), sometimes there is a need to export the geometry that has been processed (i.e. cleaned) in Hypermesh to a different preprocessor like PATRAN or ANSYS etc. in the form of an IGES or STEP file. The export is performed nicely but the suppressed lines or curves are still visible on our geometry when the file is imported in say PATRAN, thus destroying all the work done before in order to simplify the geometry. Is there an option to avoid this or it is unavoidable?
Second question (has been answered in the past): There is a popular demand to have the geometry included when exporting a bdf (NASTRAN) file from Hypermesh. Even better: If there are no legal issues, it would be extremely useful to be able to export our work directly as a db (PATRAN) file, although there will be compatibility issues between different versions. OK, having the geometry WITH the bdf export will be a killer. Do you know when this will be possible?
Thank you.
