🎉Community Raffle - Win $25
Join and Win
Imported Curves And Faces
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
After importing 3 closed curves in a DWX file, I can not manage to give all 3 faces. Curve 1 goes ok (create face from curves) Curve 2 gets a square round that after extruding leaves the curve as a hole in the square. Curve 3 I can get a face after (hmm.. forgotten what I did).
1 - 2 of 21
    User: "Darren_Chilton"
    Altair Employee
    Updated by Darren_Chilton
    If you are just trying to make holes in the circular surface as you described in your email to me you can just use the trim tool.  Just click on the Trim tool, pick the 3 polyline 2D curves, press Spacebar, pick the surface to be trimmed, press Spacebar again.
    Thanks,
    -Darren
    Altair Employee
    OP
    I learned while going image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'> Thanks anyhow
