🎉Community Raffle - Win $25
Join and Win
Initial Von Mises stresses on motorcycle frame
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Dear forum,
I am simulating a motorcycle crash with a rigid wall and I have a problem in the frame. I applied an initial velocity to all the components of model and since the first frame of the simulation there are Von Mises stresses on my frame, before impact. I wasn't able to find the problem.
I use TYPE7 contacts and rigids to join parts.
Could these stresses being caused from inertia?
Thank you in advance
1 - 6 of 61
    User: "Nachiket Kadu_22143"
    Altair Community Member
    Updated by Nachiket Kadu_22143
    Dear forum,
    How much stresses we are talking about here??
    Altair Employee
    OP
    Hi,
    Can you check if there is any initial penetration in your model?
    If possible, please share starter and engine .out files.
    Altair Employee
    OP
    I think I found the problem. I forgot to assign an initial velocity to the mass (admas) of my engine. Now the initial stresses are gone! Could this be the only problem?
    User: "Korosh_20927"
    Updated by Korosh_20927
    hi
    How can you Assign mass?
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    the procedure to add mass:
    When assigning loading like initial velocity and gravity make sure to also select nodes or components of added mass.
    thank you
