Meshing 3dimensional bodies
Hello,
I created a 3-D shaft and a 3-gear on the spin function (3D).
Then I merged over edges / equivalence both bodies
After creating a fixed and floating bearing at the shaft
and heated the shaft with
200 K, then I wanted to calculate the body with Optisctruct
Strangely, he showed me the followingerror message:
A fatal error has occurred during process
Item # 190 item type Penta
I have meshed all elements as quad4.
Have you an idea what went wrong and how can I solve the problem.
Thanks in advance
Hello,
can someone pls send me a tutorial or tell me how assembly of parts can be analysed on Hypermesh? I have analysed separate parts on Optistruct. But at the moment i want to analyse a assembly on HM. but i have no idea for that. Highly appreciate if anyone could help on this asap...
Thanks
Chanaka
Maybe you should check the components and their elements again. There must be a mistake in your components and/or elements. You could have forgotten some kind of faulty element in a component.
