Meshing 3dimensional bodies
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello,
I created a 3-D shaft and a 3-gear on the spin function (3D).
Then I merged over edges / equivalence both bodies
After creating a fixed and floating bearing at the shaft
and heated the shaft with
200 K, then I wanted to calculate the body with Optisctruct
Strangely, he showed me the followingerror message:
A fatal error has occurred during process
Item # 190 item type Penta
I have meshed all elements as quad4.
Have you an idea what went wrong and how can I solve the problem.
Thanks in advance
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2012
    Maybe you should check the components and their elements again. There must be a mistake in your components and/or elements. You could have forgotten some kind of faulty element in a component.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited July 2012
    Hello,
    can someone pls send me a tutorial or tell me how assembly of parts can be analysed on Hypermesh? I have analysed separate parts on Optistruct. But at the moment i want to analyse a assembly on HM. but i have no idea for that. Highly appreciate if anyone could help on this asap...
    Thanks
    Chanaka
  • tinh
    tinh Altair Community Member
    edited July 2012
    Hi there
    you can assemble parts using 1D/rigid RBE to make connection
    separate these RBEs into one component without card image is ok
    rgds,
Welcome!
Welcome!
