🎉Community Raffle - Win $25
Join and Win
how to automaticaly create property for each beam_section
XavierUser: "Xavier"
Altair Community Member
Updated by Xavier
is there any way to create to properties for the imported beam_sections  Pbar card image
the id number is maintained properly,
i have manually done for some values, in actual model there is a lot of values
a sample file hm file is attached for better understanding.
and test.hm file is shared, where properties needs to be created.
1 - 3 of 31
    tinhUser: "tinh"
    Accepted Answer
    Updated by tinh
    Hi,
    try this script:
    *createmark beamsects 1 all foreach bsId [hm_getmark beamsects 1] { 	set dim1 [hm_getentityvalue beamsects $bsId beamsect_dim1 0 -byid] 	set prop_name dia_[string trimright [format %.3f [expr 2*$dim1]] 0] 	*collectorcreateonly properties "$prop_name" "" 11 	*createmark properties 2 -1 	set prop_id [hm_getmark props 2] 	*dictionaryload properties 2 "[hm_info templatefilename]" "PBAR" 	*attributeupdateentity properties $prop_id 3179 1 2 0 beamsects $bsId 	*attributeupdateint properties $prop_id 3240 1 2 0 1 	*attributeupdatedouble properties $prop_id 72 1 2 0 0 	*attributeupdatestring properties $prop_id 130 1 0 0 "" 	*attributeupdateint properties $prop_id 108 1 2 0 0 	*attributeupdateint properties $prop_id 3899 1 2 0 0 }
    Tested on HM2019
    falkirk99User: "falkirk99"
    Altair Employee
    Updated by falkirk99
    I was going to recommend matrix browser route but script is easier!
    OP
    Updated by Xavier
    Hi,
    try this script:
    Tested on HM2019
    thank you sir,
    it helped alot and saved a lot of time.
