🎉Community Raffle - Win $25
Join and Win
How to isolate only failed elements
User: "Umehr Beebeejaun"
Altair Community Member
Updated by Umehr Beebeejaun
Hello to all, i would like to know how to isolate only failed elements. it is sometimes really difficult to correct an element, which is in the inside of the model.
Thanks,
Umehr
1 - 2 of 21
    User: "Ben Buchanan"
    Altair Employee
    Updated by Ben Buchanan
    There is a "save failed" option in "Element Quality".  You can then retrieve this selection and isolate those elements.  Sometimes if they are spread out it can still be hard to find so turning on the ids helps and then possibly repeating this as you correct some elements.
    Altair Employee
    You can also set the view by element quality and click on specific criteria to see the ones that are failing.
