Hypermes 2023 export to moldflow
Hi
We were working with release 2017 of Hypermesh and evrything was find when exporting to moldflow
Now we are testing the 2023 release and we have seen that everything is changed and we can't find how expport to moldflow without error
We have seen tha the 2022 version of Hyperworks has the old version of Hypernmesh 8and the export is ok) and the new (starting from Hyperworks) and this one is bad.
Do you have any idea / suggestions
Thanks
Sergio
- Create a propriety from the new tab
- in the utility tab go to "assign existing card"
- assign the propriety
- again in the utility tab export to mold flow
Hi Sergio,
Please start to use this new interface which takes place of the legacy interface. Further information here: https://web.altair.com/new-hyperworks-experience
The moldflow interface is still available from the 'Altair HyperMold' solver interface. Cf. screenshot below:
Once you've done this selection, you should be able to export a moldflow solver deck.
Regards,
Fred.
Hi Fred
This is exactly what we have done.
but we cannot export to moldflow. (there isn't any export to.udn)
thanks
Sergio
Hi Sergio,
My mistake. In order to export udm file, you must use the export tool from the Utility tab (View menu > Utility tab). Review screenshot below:
Fred.
hello Fred
Now is better we still have some issue
We have created a new propriety with the tab in the model utility but we got the error attached.
Now we are trying to create the propriety with other tab
thanks
Sergio
hello Fred
thanks
Sergio
Hi Fred
we have done some test
we could have a succesfull export but with this step
It's a mix of new and old command
We also see that assign the materials take a very long time, is it normal?
Thanks
Sergio
Hi Sergio,
Regards,
Fred.
