how come I loop through each nodes in set list
This should work...
hm_createmark nodes 1 'by set' 'Your set name'
foreach node [hm_getmark nodes 1] {
*** perform activity
Hello mahes,
set $lst_nodes [hm_createmark nodes 'by set' setname
foreach node $lst_nodes { puts $node }
Thanks Roshan and Livillyle
Hello mahes, set $lst_nodes [hm_createmark nodes 'by set' setname foreach node $lst_nodes { puts $node }
Hi, hm_createmark return an emptied string
so to get lst_nodes you have to use hm_getmark/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
Hi tinh,
Thanks tinh.
Is using createmark is the reason i cant access the nodes in the list?
And can u pls suggest me some url that will be useful for learning about basic things about hm commands like how they wrk ,wat it returns
Hi
Use *createmark nodes 1 {*}$nodelist
You can get command explaination in reference help (help>altair help home>reference>hypermesh)
Hi,
Thanks tinh
This should work...
