🎉Community Raffle - Win $25
Join and Win
perimeter shear test simulation
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hello,
i am working on a monocoque chassis and to start my analysis i wanted to simulate a perimeter shear test in hyperworks.
i have made a model with a surface and shell elements . the model is attached below.
the test involves applying constraints to the lowest surface and load on the topmost surface.
is it fine to apply fixed support on the surface excluding the lower 32mm dia circle and apllying force on the upper 25mm dia circle region.
please help it is very important for me.
1 - 7 of 71
    Altair Employee
    OP
    Hi,
    I think the 32 Dia hole is meant for scrap (Drawing technology), correct?
    If yes, Yeah you can only constraint the die
    Altair Employee
    OP
    thanks for the reply.
    the 32mm dia is for scrap.
    but how do i apply the force only  on the topmost surface of the laminate and the constraint on the lowermost layer only.
    could you please check my model file and comment if it would give me the desired results.
    Altair Employee
    OP
    HI,
    What is the objective of the simulation?
    Are you interested in forming?
    Altair Employee
    OP
    the objective of the simulation is to calculate the amount of force required to punch the 25mm dia punch completely through the laminate.
    the test is for testing monocoque laminates.
    Altair Employee
    OP
    Hi,
    I will check if HF can be a better option,
    Altair Employee
    OP
    Did you have any luck doing this, looking to do exactly the same thing, any tips would be appreciated or even your model file if you got it working would be amazing?
    Altair Employee
    OP
    On 10/3/2018 at 9:43 PM, vasudeo said:
    hello,
    hello were you able to complete the test finally i am actually stuck on the same and i want to know how you conducted the test
