Having had to use the radiation model in Acuconsole, I want able to find any info on the 'enclosure model' for radiation. Is it the same as S2S model. Any info on the matter would be great. Thank you.
Enclosure radiation model is calculating the View factors between all surfaces. So this is a Surface-Surface radiation model in that sense. See P111 of Command Reference Manual for more details on view factor calculation.
e.g. Location in your installation:
