Cannot find C/C++ Compiler
Hello,
a couple days ago i got the error message 'Simulation Error: Cannot find C/C++ Compiler'.
I downloaded the visual studio installer and installed all compilers needed. After that my simulation worked again.
Today i got the same error message again.
When i try to get the compiler path with 'vssGetCompilerPath' in the oml command box i just get the error message 'Cannot find the C/C++ compiler in call to function...'
How can i setup Activate so it finds the installed compiler?
Greetings,
Aiko
I tried reinstalling visual studio but it still doesnt work.
Maybe there is some other issue with my Activate?
When execute the 'vssGetCompilerName' i get the error message in the screenshot below, and not the 'tcc' line as it is stated in the 'Compiler Installation Guide'
Greetings,
Aiko
Hello Aiko,
Sorry when I mentionned that you need to execute the vcvarsall.bat I had to mention where you can find this file it is distribute with visual studio.
Which version of the compiler are you using?
Did you at some point change the sdk version of the compiler or intalled another sdk version?
Do you have multiple visual compilers installed?
Thanks
Fady
Hello Fady,
because i'm not that experienced with in depth compiler issues, i just followed the installation guide from this pdf.
I did not change the sdk version, i just downloaded and installed the visual studio buildtools as mentioned in the guide.
After reinstallation my Activate worked again. But today (i changed nothing related to the compiler) i get the same 'Cannot find C/C++ Compiler' error message.
It's really confusing for me, because i did not change any settings.
Is there a way to set the Compiler path directly in activate?
Greetings,
Aiko
Hello Aiko,
Are you still experiencing this issue? I've created a Tip and Trick (attached) which I believe gives the simplest steps for installing a C/C++ compiler that will be automatically recognized by Activate. Please let me know if this helps, or if you are still experiencing recognition failure please provide me the version of Activate you are running.
Take care,
Patrick
Hello ,
Activate detects automatically the installed compiler by accessing the windows registry.
Above error means that there is an issue while detecting the compiler, if you don't have any compiler, the function will return tcc; the compiler distributed with Activate.
Before digging to understand the issue, I will do the following tests:
Thanks
Fady
