🎉Community Raffle - Win $25
Join and Win
solid face offset
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
Can you suggest me what is the fastest way to offset a solid face in Hypermesh?
In the picture attached I want to reduce the shank diameter for example.
1 - 4 of 41
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    One method:
    • Extract surfaces from solid.
    • Make offset for wanted surfaces
    • Build closed surfaces
    • Create new solid from closed surfaces
    Altair Employee
    OP
    Hi Q.Nguyen,
    Thank you for the answer. So it is not possible to offset a face without extracting it from a solid right?
    Hi Q.Nguyen,
    Maybe that works too. Try it.
    Altair Employee
    OP
    Yes, it works! I had to set continuous offest (picture attached)
    Thank you.
