Hi all,
Can you suggest me what is the fastest way to offset a solid face in Hypermesh?
In the picture attached I want to reduce the shank diameter for example.
One method:
Hi Q.Nguyen,
Thank you for the answer. So it is not possible to offset a face without extracting it from a solid right?
Hi Q.Nguyen, Thank you for the answer. So it is not possible to offset a face without extracting it from a solid right?
Maybe that works too. Try it.
Yes, it works! I had to set continuous offest (picture attached)
Thank you.
