🎉Community Raffle - Win $25
Join and Win
OS-1010 - Define TEMP in Load Step
I try to follow up OS-1010: Thermal Stress Analysis of a Coffee Pot Lid using HyperWorks 2017 - Student Edition.
Everything works fine up to Step 8 Bullet 5, which is setting the Analysis type to Linear Static and SPC to constraints (Load Collector).
Unfortunately, I cannot find the settings described in Step 8 Bullet 6.
According to the tutorial (see Figure 1) I should now find TEMP in the Subcase Definition section between the Analysis types MPC and DEFORM. There, TEMP should be set to THERMAL_LOADING (Load Collector).
Fig.1:  Creating the brew cycle loadstep (Fig. 8 from tutorial OS-1010 with additional highlighting)
As I cannot find TEMP in the Subcase Definition section (see Figure 2), can I use TEMP from the Subcase Options section instead?
Has anyone here performed this tutorial successfully using HyperWorks 2017 - Student Edition?
<?xml version="1.0" encoding="UTF-8"?>58f5e4ce05daa_screenshotannotation.thumb.PNG.0beb608984e4ca93c69123337241db26.PNG
Fig.2: Screenshot from HyperWorks 2017 - Student Edition. TEMP is not available in the Subcase Definition section.
1 - 4 of 41
    Hi,
    Just scroll down using slider within entity browser, then you would find TEMP card.I think problem is because of given screenshot. PFA same.
    Thank you Rahul,
    I could find it.
    I managed to get results with some additional settings (see screenshot), but only once. Right now - unfortunately - I cannot reproduce them.
    <?xml version="1.0" encoding="UTF-8"?>screenshot-with-correct-settings+annotation.PNG
    Thanks for the update.Till 13.0 version we had TEMP option listed under linear static,from 14.0 version onward user need to call TEMP card within entity state browser.
    Now I found the correct settings! I was a little too fast with sending my previous posting.
    Setting Load Step > SUBCASE OPTIONS > TEMP > SID (LOADCOLID) > TEMP > Loadcol (THERMAL_LOADING) did not help. Using those settings only led to the following error message to be prompted:
    *** ERROR # 720 ***
     Invalid static SUBCASE that has no load or enforced displacement.
         subcase id = 1
    For a successful calculation of OS-1010 I used the following settings:
    • Load Step > SUBCASE OPTIONS > TEMP_LOAD > SID (LOADCOLID) > TEMP > Loadcol (THERMAL_LOADING)
    • Load Step > SUBCASE OPTIONS > TEMP_LOAD > SID (SUBCASEID) > TEMP > Loadcol (brew cycle)
    Figure 1 shows, where one can switch from LOADCOLID TO SUBCASEID and vice versa.
    <?xml version="1.0" encoding="UTF-8"?>screenshot-showing-where-to-switch-between-LOADCOLID-and-SUBCASEID.thumb.PNG.c7bc83a7854bc64922884dc6e8abcea9.PNG
    Figure 1: Switching from LOADCOLID to SUBCASEID and vice versa.
