🎉Community Raffle - Win $25
Join and Win
Solving Problem - executeAlgo_c : Execution failed.
User: "Magneto"
New Altair Community Member
Updated by Magneto
Hello,
I have a problem solving a Flux 2d magneto static project (axissymmetric). The geometry check, mesh check and physical check shows no error. If I start solving the scenario this is written in the output window:
Begin of physical check ...
The final derivative of points defining the spline curve of material E235C must be equal to Mu0. The final relative permeability is equal to: 0.27947406883797
Please, verify the properties of the material: E235C
An electric circuit exists.
The active physical application does not take account of it.
End of physical check.
Automatic selection between local and distributed MUMPS...
Setting solver for presolving : Mumps Local
Setting solver for solving : Mumps Local
08:07:15    5776 sec. Start save ...
08:07:16    5777 sec. ... end save
Active formulation(s) :
MSAVEC : Axisymmetric magnetostatic vector potential formulation
Matrix system : non linear, real, symmetrical
08:07:16    5778 sec. Start solving problem ...
Step number 1
Value of parameter ELFORC_TRANSLATION_ANKER : None
Value of parameter LINPOS_TRANSLATION_ANKER : -.3E-03
Value of parameter VAR_STROM : 0.3
08:07:30    5791 sec. Start creating Dirichlet constraints at points...
08:07:30    5791 sec. ... end creating Dirichlet constraints at points.
08:07:30    5791 sec. Start save ...
08:07:32    5793 sec. ... end save
Mesh of compressible domains ...
08:08:07    5828 sec. Generating 2nd order elements is running
  Total number of nodes --> 551232
08:08:10    5831 sec. End generating 2nd order elements
  RAN1 unknowns are initialized to zero
08:08:16    5837 sec. Numbering of   551232 nodal values done.
08:08:16    5837 sec. Number of non zero matrix elements estimated to be    22055440
Non managed error which has stopped solving process
08:08:16    5837 sec. Start save ...
08:08:16    5837 sec. ... end save
08:08:16    5838 sec. Start reading ...
08:08:18    5839 sec. ... end reading
08:08:18    5839 sec. ... end solving problem.
executeAlgo_c : Execution failed.Failed execution
ERROR: Advanced
PBEPAV_3 => Error 49, no treated error type
PBCEVL_4 => failed
PBCEVL_3 => Failed
PBERES_3 => failed
FL5RE4   => Command not executed correctly
FL5ERS   => failed
FL5ERS_1 => failed
executeAlgo_c => failed
stdcom.error.SoftwareFortranException: executeAlgo_c : Execution failed.
Failed execution
    at cad.core.common.error.ErrorManager.createFortranException(ErrorManager.java:170)
    at cad.flux.kernel.dbmanager.FGCProjectDbWrapper.executeAlgo(Native Method)
    at cad.flux.kernel.dbmanager.FGCProjectDbAdapter.executeAlgo(FGCProjectDbAdapter.java:902)
    at cad.flux.kernel.dbmanager.FGCDbManager.executeAlgo(FGCDbManager.java:151)
    at cad.flux.kernel.FGSupervisor.executeNativeCommand(FGSupervisor.java:2169)
    at cad.flux.kernel.actions.implementation.algo.project.KSolveScenarioAction.doAction(KSolveScenarioAction.java:83)
    at cad.core.common.dynamic.actions.UIActionManager.postAction(UIActionManager.java:145)
    at cad.core.kernel.KernelCommon.postAction(KernelCommon.java:347)
    at cad.core.kernel.Supervisor.executeJavaCommand(Supervisor.java:2862)
    at cad.core.kernel.Supervisor.executeCommand(Supervisor.java:2040)
    at cad.core.kernel.Supervisor.executeMethod(Supervisor.java:2159)
    at sun.reflect.GeneratedMethodAccessor380.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:498)
    at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
    at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:206)
    at org.python.core.PyObject.__call__(PyObject.java:545)
    at org.python.core.PyObject.__call__(PyObject.java:551)
    at org.python.core.PyMethod.__call__(PyMethod.java:171)
    at pydb$py.executeMethod$205(pydb.py:1617)
    at pydb$py.call_function(pydb.py)
    at org.python.core.PyTableCode.call(PyTableCode.java:171)
    at org.python.core.PyBaseCode.call(PyBaseCode.java:171)
    at org.python.core.PyFunction.__call__(PyFunction.java:434)
    at org.python.core.PyMethod.__call__(PyMethod.java:156)
    at pydb$py.__call__$172(pydb.py:1390)
    at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
    at org.python.core.PyBaseCode.call(PyBaseCode.java:199)
    at org.python.core.PyFunction.__call__(PyFunction.java:482)
    at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:237)
    at org.python.core.PyMethod.__call__(PyMethod.java:228)
    at org.python.core.PyMethod.__call__(PyMethod.java:223)
    at org.python.core.PyObject.invoke(PyObject.java:3715)
    at org.python.core.PyInstance.instance___call__(PyInstance.java:377)
    at org.python.core.PyInstance.__call__(PyInstance.java:372)
    at org.python.core.PyObject.__call__(PyObject.java:424)
    at org.python.pycode._pyx237.f$0(<input>:1)
    at org.python.pycode._pyx237.call_function(<input>)
    at org.python.core.PyCode.call(PyCode.java:18)
    at org.python.core.Py.runCode(Py.java:1625)
    at org.python.core.Py.exec(Py.java:1669)
    at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
    at cad.core.kernel.components.PythonWrapper.runCode(PythonWrapper.java:628)
    at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:623)
    at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:598)
    at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:593)
    at cad.core.kernel.components.PythonWrapper.execute(PythonWrapper.java:638)
    at cad.core.kernel.components.PythonWrapper.executeFunction(PythonWrapper.java:706)
    at cad.core.kernel.encoder.CommandServerRequestsInputPlug.executeCommand(CommandServerRequestsInputPlug.java:79)
    at stdcom.protocole.commandserverrequests.CommandServerRequestsRouter.executeCommand(CommandServerRequestsRouter.java:70)
    at stdcom.protocole.commandserverrequests.CommandServerRequestsOutputPlug.executeCommand(CommandServerRequestsOutputPlug.java:111)
    at cad.core.frontal.decoder.FrontalDecoder.executeCommand(FrontalDecoder.java:692)
    at cad.core.frontal.actions.implementation.GeneralAction.executeBox(GeneralAction.java:286)
    at cad.flux.frontal.actions.implementation.algo.project.FAbstractSaveAsAction.executeBox(FAbstractSaveAsAction.java:93)
    at cad.core.frontal.actions.implementation.GeneralAction.postAct(GeneralAction.java:254)
    at cad.core.frontal.actions.implementation.GeneralAction.interpret(GeneralAction.java:315)
    at cad.core.frontal.components.box.frontaldialog.FrontalDescriptorDialogBox.internalRun(FrontalDescriptorDialogBox.java:296)
    at cad.core.frontal.frontalthread.WorkerThread.executeImplementer(WorkerThread.java:226)
    at cad.core.frontal.frontalthread.WorkerThread.run(WorkerThread.java:274)
Someone an idea which can cause this error? I have build up nearly the same model last week, without any complication.
1 - 4 of 41
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    Maybe the problem come form the material that you use. When you do check physics, you get this warning:
    Can you try to change the material and try to solve again the project.
    If the problem persist, can you shar the Flux project.
    Best regards.
    User: "Magneto"
    OP
    Updated by Magneto
    Hello,
    sorry for the late response. In fact I solved the problem. First of all the fact, that the flux project can be solved in a static scenario, without a translation part, let me think that FLUX could have some issues with geometry identification and/or remeshing during the multistatic simulation.
    The failure was caused by the Geometry (*.stp). For this analysis I modified an existing step-model in hypermesh. This leads to the fact, that in the exported new *.step file there where two 'parts' in the part browser in hypermesh. When I modified the stepfile again by deleting one of the 'parts' (not components!!!) Flux was able to solved the project.
    To find this problem I was in contact with the Altair Flux support. He has no idea, why this caused such a problem. He forward the Support-Ticket to Hypermesh-Support. Maybe they have an idea.
    Best regards.
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    Thanks for your feedback. I'm curious to know where the problem comes from.
    Can you share the step and Flux project.
    Best regards.
    User: "Andoni Garcia"
    Updated by Andoni Garcia
    Dear magneto,
    I would like to get more details about the way you solved that file.
    I have been simulating some files that didn't have solved because it jumped your same error and nobody could get solved it.
    Best regards,
    Andoni
