I have a problem solving a Flux 2d magneto static project (axissymmetric). The geometry check, mesh check and physical check shows no error. If I start solving the scenario this is written in the output window:
Begin of physical check ...
The final derivative of points defining the spline curve of material E235C must be equal to Mu0. The final relative permeability is equal to: 0.27947406883797
Please, verify the properties of the material: E235C
An electric circuit exists.
The active physical application does not take account of it.
End of physical check.
Automatic selection between local and distributed MUMPS...
Setting solver for presolving : Mumps Local
Setting solver for solving : Mumps Local
08:07:15 5776 sec. Start save ...
08:07:16 5777 sec. ... end save
Active formulation(s) :
MSAVEC : Axisymmetric magnetostatic vector potential formulation
Matrix system : non linear, real, symmetrical
08:07:16 5778 sec. Start solving problem ...
Step number 1
Value of parameter ELFORC_TRANSLATION_ANKER : None
Value of parameter LINPOS_TRANSLATION_ANKER : -.3E-03
Value of parameter VAR_STROM : 0.3
08:07:30 5791 sec. Start creating Dirichlet constraints at points...
08:07:30 5791 sec. ... end creating Dirichlet constraints at points.
08:07:30 5791 sec. Start save ...
08:07:32 5793 sec. ... end save
Mesh of compressible domains ...
08:08:07 5828 sec. Generating 2nd order elements is running
Total number of nodes --> 551232
08:08:10 5831 sec. End generating 2nd order elements
RAN1 unknowns are initialized to zero
08:08:16 5837 sec. Numbering of 551232 nodal values done.
08:08:16 5837 sec. Number of non zero matrix elements estimated to be 22055440
Non managed error which has stopped solving process
08:08:16 5837 sec. Start save ...
08:08:16 5837 sec. ... end save
08:08:16 5838 sec. Start reading ...
08:08:18 5839 sec. ... end reading
08:08:18 5839 sec. ... end solving problem.
executeAlgo_c : Execution failed.Failed execution
ERROR: Advanced
PBEPAV_3 => Error 49, no treated error type
PBCEVL_4 => failed
PBCEVL_3 => Failed
PBERES_3 => failed
FL5RE4 => Command not executed correctly
FL5ERS => failed
FL5ERS_1 => failed
executeAlgo_c => failed
stdcom.error.SoftwareFortranException: executeAlgo_c : Execution failed.
Failed execution
at cad.core.common.error.ErrorManager.createFortranException(ErrorManager.java:170)
at cad.flux.kernel.dbmanager.FGCProjectDbWrapper.executeAlgo(Native Method)
at cad.flux.kernel.dbmanager.FGCProjectDbAdapter.executeAlgo(FGCProjectDbAdapter.java:902)
at cad.flux.kernel.dbmanager.FGCDbManager.executeAlgo(FGCDbManager.java:151)
at cad.flux.kernel.FGSupervisor.executeNativeCommand(FGSupervisor.java:2169)
at cad.flux.kernel.actions.implementation.algo.project.KSolveScenarioAction.doAction(KSolveScenarioAction.java:83)
at cad.core.common.dynamic.actions.UIActionManager.postAction(UIActionManager.java:145)
at cad.core.kernel.KernelCommon.postAction(KernelCommon.java:347)
at cad.core.kernel.Supervisor.executeJavaCommand(Supervisor.java:2862)
at cad.core.kernel.Supervisor.executeCommand(Supervisor.java:2040)
at cad.core.kernel.Supervisor.executeMethod(Supervisor.java:2159)
at sun.reflect.GeneratedMethodAccessor380.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:206)
at org.python.core.PyObject.__call__(PyObject.java:545)
at org.python.core.PyObject.__call__(PyObject.java:551)
at org.python.core.PyMethod.__call__(PyMethod.java:171)
at pydb$py.executeMethod$205(pydb.py:1617)
at pydb$py.call_function(pydb.py)
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.PyBaseCode.call(PyBaseCode.java:171)
at org.python.core.PyFunction.__call__(PyFunction.java:434)
at org.python.core.PyMethod.__call__(PyMethod.java:156)
at pydb$py.__call__$172(pydb.py:1390)
at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
at org.python.core.PyBaseCode.call(PyBaseCode.java:199)
at org.python.core.PyFunction.__call__(PyFunction.java:482)
at org.python.core.PyMethod.instancemethod___call__(PyMethod.java:237)
at org.python.core.PyMethod.__call__(PyMethod.java:228)
at org.python.core.PyMethod.__call__(PyMethod.java:223)
at org.python.core.PyObject.invoke(PyObject.java:3715)
at org.python.core.PyInstance.instance___call__(PyInstance.java:377)
at org.python.core.PyInstance.__call__(PyInstance.java:372)
at org.python.core.PyObject.__call__(PyObject.java:424)
at org.python.pycode._pyx237.f$0(<input>:1)
at org.python.pycode._pyx237.call_function(<input>)
at org.python.core.PyCode.call(PyCode.java:18)
at org.python.core.Py.runCode(Py.java:1625)
at org.python.core.Py.exec(Py.java:1669)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
at cad.core.kernel.components.PythonWrapper.runCode(PythonWrapper.java:628)
at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:623)
at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:598)
at cad.core.kernel.components.PythonWrapper.runsource(PythonWrapper.java:593)
at cad.core.kernel.components.PythonWrapper.execute(PythonWrapper.java:638)
at cad.core.kernel.components.PythonWrapper.executeFunction(PythonWrapper.java:706)
at cad.core.kernel.encoder.CommandServerRequestsInputPlug.executeCommand(CommandServerRequestsInputPlug.java:79)
at stdcom.protocole.commandserverrequests.CommandServerRequestsRouter.executeCommand(CommandServerRequestsRouter.java:70)
at stdcom.protocole.commandserverrequests.CommandServerRequestsOutputPlug.executeCommand(CommandServerRequestsOutputPlug.java:111)
at cad.core.frontal.decoder.FrontalDecoder.executeCommand(FrontalDecoder.java:692)
at cad.core.frontal.actions.implementation.GeneralAction.executeBox(GeneralAction.java:286)
at cad.flux.frontal.actions.implementation.algo.project.FAbstractSaveAsAction.executeBox(FAbstractSaveAsAction.java:93)
at cad.core.frontal.actions.implementation.GeneralAction.postAct(GeneralAction.java:254)
at cad.core.frontal.actions.implementation.GeneralAction.interpret(GeneralAction.java:315)
at cad.core.frontal.components.box.frontaldialog.FrontalDescriptorDialogBox.internalRun(FrontalDescriptorDialogBox.java:296)
at cad.core.frontal.frontalthread.WorkerThread.executeImplementer(WorkerThread.java:226)
at cad.core.frontal.frontalthread.WorkerThread.run(WorkerThread.java:274)
Someone an idea which can cause this error? I have build up nearly the same model last week, without any complication.
