Define load step for a heat flux
Hello everyone!
When I import a heat flux from the field option (as a .csv), it creates a load collector that is empty. Does anyone know how to relate these elements?
to create the flux i import it in fields->csv->realize->select faces->convection->proximity->realize
From the contour option it seems that it is imported correctly, and the conduction elements are created. I just dont know how to continue and create the thermal load to proceed with the analysis.
Thanks everyone!
1 - 1 of
11
Hi Alvaro
Which version of Hypermesh / Optistruct are you using?
Below are some links to the Optistruct manual that might help you!
Linear Transient Heat Transfer Analysis (altair.com)
OS-T: 1090: Linear Transient Heat Transfer Analysis of an Extended Surface Heat Transfer Fin (altair.com)
/Johan
