🎉Community Raffle - Win $25
Join and Win
RLOAD
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hallo I am having following questions
1) I am doing Modal Frequency response simulation
In  RLoad load collector  there is field called TC (see attached file) which expects input in tabular form  i have solver deck
in it the values in table is
X(1)= 0.0 Y(1)= 1.0, X(2)= 5000 , Y(2)= 1.0
what is this C ( Damping?), Is it material dependant? how is this tabular input defined
2) There is SDamping Control Card
I want to know how is the the value of g defined in TABDMP1 table in my case it is 0.02. Is it default? Again is it Material dependent?
Thanks and Regards
Pratik
<?xml version="1.0" encoding="UTF-8"?>post-36734-0-63033500-1427125658_thumb.j
1 - 3 of 31
    Altair Employee
    OP
    Hi Pratik,
    TABLEDi define C, In other words TC is the C in the equation.
    Assuming you are apply a structural damping then you have to select CRIT as type in TABDAMPi card. Here G is 2*Critical damping.
    Altair Employee
    OP
    Hi Prakash Thanks for your reply
    I would still like to know what physical quantity does this C represent or  how it is tio be  modelled.
    Altair Employee
    OP
    HI,
    C is the dynamic parameter (time or frequency function) (TABLEDi)  in the Equation.
