🎉Community Raffle - Win $25
Join and Win
How to extract the strain component on a surface location of a solid?
Hi all,
My model was built with tetra solid elements, and a structural analysis was solved.
In the test, the strain of some points on the solid structure surface were gotten by strain gauges. I want to compare the strain component from my simulation with the test result. However, my problem is how to extract the strain result on the surface of a tetra solid model in optistruct?
Thank you
1 - 5 of 51
