Good evening
I am currently facing issues with my model. It only seems to run analysis even though i have set it up for optimization. I have double checked everything that i set-up in my topology, responses, constraints and objectives as well.
I have also double checked that my input is Analysis>Optistruct>Run Options>Optimization.
But the file only runs for an analysis. It doesnt go ahead and remove all the material as it generally does in optimization.
Any help would be highly appreciated.
Thank you
