🎉Community Raffle - Win $25
Join and Win
Update Hypermesh Extensions
User: "tinh"
Altair Community Member
Updated by tinh
Hello everybody
This is a script to project nodes on elems:
< a simple script so i do not make package index & installer, you have to source it or invoke menu File>Run>Tcl/Tk Script
I made a new function for Hypermesh to export entity by right-click on model browser
Open Hypermesh, from menu File>Run>Tcl/Tk Script , browse to Installer.tcl in folder MenuExportDeck to install it in hmcustom.tcl
I made a new function for Hypermesh to copy mesh among sessions
  <updated for HM2017> + <update installer.tcl to install in any folder>
Please announce me if any error.
- 'Extract here' package hmcp.zip, copy the folder 'hmcp' to anywhere you want to store.
- Open hypermesh and run Installer.tcl file by enter menu File>Run >Tcl/Tk Script
- start Hypermesh, it should shows an icon and provide some information like below:
- You can copy elements selected in any current panel:
- Once again, this topic is to introduce extensions for Hypermesh. I let updated version of hmdnd (drag and drop function) here
<updated installer.tcl so you can install it to any folder, just open hypermesh and File>Run>Tcl/tk script to run installer.tcl>
related post:
https://community.altair.com/community?id=community_question&sys_id=633648761b2bd0908017dc61ec4bcba6
- And a package to help making your own toolbars: tbopts.zip
  <update installer.tcl so you can install it to any folder>
  <fix bugs while running on HM2019.1>
related post
https://community.altair.com/community?id=community_question&sys_id=ab3648761b2bd0908017dc61ec4bcba6
1 - 12 of 121
    User: "evsm1982"
    Updated by evsm1982
    Hello,
    I have tried this script and works fine in hm 13 and 14 sessions.
    Seems not OK when I have tried to copy some elements between hm 12 sessions 'Error while copying data'.
    Is there any way to add nodes option to be copied between sessions?
    I create nodes using coordinates from one session to other.
    Thank you.
    User: "tinh"
    OP
    Updated by tinh
    Hi,
    yes, it is possible to copy node only, i may add this feature. But just now you can copy elements and then shift f2 > add temp nodes > delete elems
    i also face problem with HM12, but should we forget it soon? higher version is better anyway
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Hi @tinh,
    How to make your customization toolbar appear below 'fixed point' toolbar?
    (See yellow mark on attach picture)
    Thank you,
    Best regards,
    Iron_Man
    User: "tinh"
    OP
    Updated by tinh
    Hi,
    open command window and type in:
    HM_Framework::p_GetMinibarIconList Display
    you will see the code to add a button to the toolbar
    you can create your own toolbars, But hypermesh 2017 turn to release new GUI, I think much nicer, so forget these toolbars.
    refer to:
    User: "Udhay Rohith"
    Updated by Udhay Rohith
    Hi tinh,
    I have checked this with HM 2017 and it showing the following error. How can we avoid this?
    User: "tinh"
    OP
    Updated by tinh
    Hello @Udhay Rohith
    Because I am using hm13, so I will check it on hm2017 and update to you soon.
    Altair Employee
    Thanks @tinh for this. I am new to hypermesh and I want to learn TCL scripting for hm. Can you guide me from where I should start?
    User: "tinh"
    OP
    Updated by tinh
    hI
    To start learning tcl scripting in hm, enter menu Help > Altair Help Home .
    => Reference Guide => Hypermesh
    In Hypermesh Reference Guide, read section 'Scripts'
    do some examples, and read some sample scripts in ~altair/14.0/hm/scripts
    User: "tinh"
    OP
    Updated by tinh
    Hi tinh,
    Hi,
    I checked it with hm2017, there is a change in dataname so output version of copied data is incorrect
    This is update package to use with HM2017:
    [above link was updated, please download it]
    User: "tinh"
    OP
    Updated by tinh
    Update a function to export entity by righ-click on model browser
    (Download MenuExportDeck.zip at 1st post)
    It can save geometry of components ! so if you want do divide cad parts, you don't need to delete-then-save
    MenuExportDeck.png.fafa613841acc4ee9c1449d5579fc9b6.png.109b690ccc753b592ae8c12c8576b720.png
    User: "Danielle_21252"
    Altair Employee
    Updated by unknown
    Hi @tinh this is a great post. Thanks for sharing. You should post this content in a Blog instead of Question...you get more points in the Community by creating these nice How-To blogs.
    User: "Andrew_22514"
    Updated by Andrew_22514
    Hi @tinh I was wondering if you are able to share the source code of your MenuExportDeck.zip file. I noticed that the source .tcl file is bytecode. I'm looking to add my own scripts to the right-click menu in the model browser and was hoping to use your MenuExportDeck as a guide.
    Can you also point me in the right direction for any documentation on how to do this?
    Thanks
