🎉Community Raffle - Win $25
Join and Win
Hypermesh
User: "Manoj Yandra"
Altair Community Member
Updated by Manoj Yandra
How to equivalence temp nodes with element nodes using hypermesh tcl commands
1 - 8 of 81
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    The equivalence function does not work with temp nodes, only with meshing nodes.
    But you can write a Tcl script to move your element nodes to temp nodes.
    OP
    i thought of using replace option, but that involves replacing of some 300 nodes.
    What kind of script are u suggesting about?
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    select all temp nodes
    find closest node
    replace
    300 or 3000 nodes is the same method.
    Koga gives you already the ... code :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
    User: "mertbuldu"
    New Altair Community Member
    Updated by mertbuldu
    You can follow below pictures.
    resim.png.6ec053e7b1998e7d7090921bf330d9e5.pngresim.png.caf195f2248707aa9f9febc58cacde56.pngresim.png.49411fad0825896e75d54a5e24d842e3.pngresim.png.24af8c90a09bcd998f469696e0fa9d12.png
    User: "tinh"
    Updated by tinh
    Another way:
    create a rigidlink or mass elements on temp nodes and then do equivalence
    Another way:
    Ah, that's a GOOD idea! :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
    OP
    Thank You everyone for your suggestions.
