🎉Community Raffle - Win $25
Join and Win
EDEM-Fluent coupling: particle density
User: "Zilong Qiu"
Altair Community Member
Updated by Zilong Qiu
Hi,
A question about what will happen if the particle density is different in EDEM and Fluent input. The particle behavior in the fluid seems very different if a large difference is given.
In which source file the particle density will be used in the Fluent-EDEM coupling interface? and what is the role of the particle density in the two-way coupling calculation?
Thank you for your help in advance!
Best regards,
Zilong
