CBAR/CBEAM Stresses vs Element Stress (1D)
LFSS
LFSS Altair Community Member
edited October 2020 in Community Q&A
Hello,
i'm trying to figure out what's the difference between these two output options.
CBAR/CBEAM gives me normal stresses while Element Stress gives me Axial Stress. The difference between results is an order of magnitude apart, so I really need to know what each one is actually outputting. I've search the documentation but I couldn't find a suitable answer.
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited July 2020
    i believe that you're getting normal stresses as a combination of axial+flex stress in a certain point of your beam. (depends on where are your evaluation points).
    If it was tension;/compression only, they should match.
  • LFSS
    edited July 2020
    Yeah, I checked and there's flexing.
Welcome!
Welcome!
