🎉Community Raffle - Win $25
Join and Win
Remove error
User: "Jouher_20929"
Altair Community Member
Updated by Jouher_20929
@tinh @Pandurang
I have option for selection of node (*createmarkpanel) followed by set of operations. If, i am not selecting any node, while execution of command, I want to exit from command instead of throwing errors. please help me to sort this out.
1 - 9 of 91
    User: "Imoto"
    Altair Employee
    Updated by Imoto
    Hi Jouher,
    *createmarkpanel nodes 1 'Please select nodes';
    if {[hm_marklength nodes 1] > 0} {
     *nodemarkaddtempmark 1;
    } else {
     tk_messageBox -message '0 nodes selected' -icon error;
    Or You can use 'catch' command.
    https://www.tcl.tk/man/tcl8.4/TclCmd/catch.htm
    Thanks,
    Imoto
    OP
    Thanks @Imoto ,
    But, If i select any node, then press esc it wont work. similarly for string too, if I type name and instead of proceed, if i press esc key, it will proceed further.
    Please help me to solve this too.
    User: "tinh"
    Updated by tinh
    Hi Jouher,
    so you want : press ESC => will NOT proceed, don't you?
    I had the code
    OP
    Hi Jouher,
    I had the code
    Yes, @tinh
    User: "Imoto"
    Altair Employee
    Updated by Imoto
    Hi Jouher,
    You can add the bind for Escape key.
    proc ESCkeyClearAll {args} {
     hm_markclearall 1;
     hm_markclearall 2;
    bind . <Escape> ESCkeyClearAll
    } else {
     tk_messageBox -message '0 node selected' -icon error;
    Thanks,
    Imoto
    OP
    Hi Jouher,
     hm_markclearall 1;
     hm_markclearall 2;
    } else {
    Thanks,
    Imoto
    Its not working
    User: "tinh"
    Updated by tinh
    Hi
    we should not bind a script to '.' toplevel, because it will trigger every widgets
    the main widget receives ESC key to exit panel is .hmContainer
    User: "Imoto"
    Altair Employee
    Updated by Imoto
    Thanks Tinh,
    bind .hmContainer <Escape> {hm_markclearall 1; hm_markclearall 2; hm_notifykeydown %N %k;}
    User: "tinh"
    Updated by tinh
    I wrote a proc like this:
    proc p_SelectMark {EntityType MarkId args} {
            #this binding code can be set once at level #0, but i embed here, so this proc is working everytime
             if {![string match '*set ::v_PressEsc 1*' [bind .hmContainer <Key-Escape>]]} {
                    bind .hmContainer <Key-Escape> {+set ::v_PressEsc 1}
             if {![hm_info functionlock]} {
                    set ::v_PressEsc 0
                   *createmarkpanel $EntityType $MarkId $args
                    if {$::v_PressEsc} {
                        *clearmark $EntityType $MarkId
                    hm_getmark $EntityType $MarkId
