rexxar
rexxar
rexxar Altair Community Member
edited October 2020 in Community Q&A
Hello,
Im working on simulation for induction motor. But i'm little bit confused with making a circuit. The example A is from flux tutorial and B is something what i made.
1. In example A, is this circuit represent star connection of stator (all coil conductor connected in one point and one ground) or can i connected them seperate like is example B (every circuit, coil have ground connection) and what is the diffrence ?
2. How to connect squirrel cage. Are he need to bee connected to the circuit like in example A or can he be connected separately to the ground like a example B ?
Thank you,
Best regards.
<?xml version="1.0" encoding="UTF-8"?>Untitled12.thumb.png.b77b6343a5e13e3888f3435deac46fb6.png
Welcome!
Answers
  • fzidat
    fzidat
    Altair Employee
    edited July 2020
    Hello;
    If the you supply with balanced three phase current system, A or B are OK. If you supply with Voltage sources, you need to use A. But why do you want to use B configuration ?
    Please find bellow the answers to your questions:
    1- A is a star connection, but you need to add in parallel a big resistance:
    2- The squirrel cage component need to be connected to the ground, so even in Circuit A, you can connect it seprately to the ground.
    Regards
  • rexxar
    edited July 2020
    Thank you very much for fast reply.
    So if i want simulate delta connection it will be like this.
  • asoualmi
    asoualmi
    Altair Employee
    edited July 2020
    Hi,
    Find attached a PDF file which sommeriez the different configurations of electrical circuit.
    Best regards
  • rexxar
    edited July 2020
    Hi,
    Best regards
    Thank you very much on that PDF!!
  • asoualmi
    asoualmi
    Altair Employee
    edited July 2020
    You are welcome.
Welcome!
Welcome!
