Im working on simulation for induction motor. But i'm little bit confused with making a circuit. The example A is from flux tutorial and B is something what i made.
1. In example A, is this circuit represent star connection of stator (all coil conductor connected in one point and one ground) or can i connected them seperate like is example B (every circuit, coil have ground connection) and what is the diffrence ?
2. How to connect squirrel cage. Are he need to bee connected to the circuit like in example A or can he be connected separately to the ground like a example B ?
Thank you,
Best regards.
