Altair RISE
Nominate Yourself Now!
Show elements in a pre-defined set in hw
User: "Guy01"
Altair Community Member
Updated by Guy01
Hello
Can anyone help me to do a 'isolate only' type of operation by command?
I would like to display results on a set defined in hyperview.
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page1 [proj GetActivePage ]
page1 GetWindowHandle win1 [page1 GetActiveWindow]
win1 SetClientType 'Animation'
win1 GetClientHandle po1
po1 GetModelHandle mo1 [po1 GetActiveModel ]
mo1 GetSelectionSetList # i can see the available set list with this command
I cant find the way to select only a particular set (knowing its name or id).
Thanks in advance for the help
1 - 6 of 61
    User: "Guy01"
    OP
    Updated by Guy01
    Hello again
    I never undertood when experts like you dont want to answer questions. Is it that the question is too hard to answer or too dumb?
    Or is it such a secret that you don't want to reveal it?
    Sometimes a simple answer like 'NO we cant do that' is sufficient and it is confusing to see no reply.
    Anyways you guys provided help till now so thanks for that. I will surely find myself answer for this soon.
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Calme-toi !!!
    User: "Guy01"
    OP
    Updated by Guy01
    TG toi!
    User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Hi Roche,
    You can try the below commands to Set you need:
      set setHandle [$modelHandle GetSelectionSetHandle setH1 'Set $id']  set nameSet [setH1 GetLabel]  # Can also be:   set setHandle [$modelHandle GetSelectionSetHandle setH2 'User_Set $id']  set nameSet [setH2 GetLabel]  # User_Set or Set are called pool can be found through GetPoolList  # Refer documentation for more info.
    User: "tinh"
    Updated by tinh
    Hello again
    I don't have an answer but I will not say no we can't do because someone else could have right answer, just he is busy. ^_^/emoticons/default_happy.png' srcset='/emoticons/happy@2x.png 2x' title='^_^' width='20' />
    User: "Guy01"
    OP
    Updated by Guy01
    Hi Livil Lyle
    Thanks for the code, that helped.
    Below code to do a 'isolate only' operation by commands. I tried this today and it works!
