🎉Community Raffle - Win $25
Join and Win
How to integrate Simlab python script(shell mesh creation) and hyper mesh TCL script(solid mesh creation)? how to combine both operations using OML-Python bridge & OML-TCL bridge?
User: "Vaddi Vijay Kumar"
Altair Community Member
Updated by Vaddi Vijay Kumar
1 - 1 of 11
    User: "AlessioLibrandi"
    Altair Employee
    Updated by AlessioLibrandi
    Please have a look at this article that may help you further.
    Greetings, Alessio Librandi
    ___________________________________
    Run a HyperMesh script (*.tcl) from SimLab Using a Python File and using batch commands.
    When a user tries to run the HyperMesh script from SimLab, the 'ALTAIR_HOME' env will be changed and it will conflict with the HyperMesh installation path.
    The conflict can be avoided using the below methods.
    1. Using the following Python code
    CODE:
    #import subprocess module is used for accessing the system commands  import subprocess ,os  #To avoid the conflict between the SimLab and HyperMesh installation path store the ‘ALTAIR_HOME’ env in a python variable and clear the env.  Altair_Home = os.environ["ALTAIR_HOME"]  os.environ["ALTAIR_HOME"]=''  #Store the tcl script path and HyperMesh installation path in a python variable.  TCLScript = "./HM_Script.tcl"  hmBatchLoc = "./../hwdesktop/hm/bin/win64/hmbatch.exe"  #To start HyperMesh and execute the tcl script in batch mode use the below codes  Arg= hmBatchLoc+ " -tcl " + TCLScript  subprocess.call(Arg)  #After executing the tcl script restore back the ‘ALTAIR_HOME’ env  os.environ["ALTAIR_HOME"] = Altair_Home
    SAMPLE SCRIPT:
    import subprocess,os  Altair_Home = os.environ["ALTAIR_HOME"]  os.environ["ALTAIR_HOME"]=''  TCLScript = ""C:/Users/Documents/HyperMesh_Scripts/HM_Script.tcl"  hmBatchLoc = "C:/Program Files/Altair/HM_2021.2/hwdesktop/hm/bin/win64/hmbatch.exe"  Arg= hmBatchLoc+ " -tcl " + TCLScript  subprocess.call(Arg)  os.environ["ALTAIR_HOME"] = Altair_Home
    2. Using the following batch script
    Use 'setlocal' and 'endlocal' batch commands as below to avoid this conflict.
    BATCH SCRIPT:
    REM To get the script file to be executed in SimLab
    set script_name=D:\\Script\\simlab.py
    REM To get the SimLab.bat location
    set simlab_bat=D:\\Altair\\SimLab_2022.1\\SimLab.bat
    REM To get the ALTAIR_HOME path and launch HyperMesh
    set ALTAIR_HOME=D:\\Altair\\Hw_2021
    set hmbatch=%ALTAIR_HOME%\\hwdesktop\\hm\\bin\\win64\\hmbatch.exe
    REM To localize the changes made to the variable 'ALTAIR_HOME'
    setlocal
    REM Launching SimLab.bat and executing the python script.
    call %simlab_bat% -auto %script_name% -nographics
    REM To revert back the changes made to the variable.
    endlocal
    REM Launching HyperMesh and executing the tcl script.
    start %hmbatch% -nocommand -h -tcl %script_path%\HM_Script.tcl
