how to do toggle the solid edge line
hello every one ,
now i practise steering wheel in hexa mesh , first i split solid (using line) separate the solid after i convert into single solid i can not toggle the split line , any one give suggestion , check below attachement .hm file and snap
thanks
Regards
Yukesh
1 - 2 of
21
@Rahul R here i make hexa mesh in check below snap , if i select along surface i cannot selected single surface i try toggle not working so what can i do
Once you split solid body it can not be toggled.You can merge two bodies (use solid edit : merge )then you can suppress split line.
