🎉Community Raffle - Win $25
Join and Win
Motion view Damping force Output
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
How to get damping force output of a spring damper system?
The standard output method through spring damper entity selection gives combined spring+damping force as a output.
1 - 1 of 11
    Altair Employee
    OP
    To Get Damper forces you can create Spring Damper with Damper properties only do not define any stiffness value and then measure the outputs on Spring damper, which are based on your damping inputs.
    Regards,
    Gitesh
