How to get damping force output of a spring damper system?
The standard output method through spring damper entity selection gives combined spring+damping force as a output.
To Get Damper forces you can create Spring Damper with Damper properties only do not define any stiffness value and then measure the outputs on Spring damper, which are based on your damping inputs.
Gitesh
