Requesting Output of each ply (Abaqus solver)
Hello there,
I setup a shell composite layup using HyperMesh to solve it via Abaqus. I need to analyse the output of each ply. I was told that I can do that by putting the following commands into my input file:
So that (i used 3 integration points per ply) I do get the results for each ply individually, regarding to the Abaqus documentation (https://abaqus-docs.mit.edu/2017/English/SIMACAECAERefMap/simacae-c-advlayupsoutput.htm).
So i do have 7 plies, whith 3 integration points each.
What I am currently wondering about is how to get that information printed to my .dat file.
I used the following commands:
The output now looks like that:
I expected 21 outputs per element. I am using S4 Shell elements so i feel like PT 1...4 means it does that for each individual integration point of my element but why only for 4 sections points each?
I kinda feel like I got mixed up with integration and section points here.
I tried to visualize my problem roughly to make clear what infos I try to generate. So I wanna print out the results for the black crosses with the red circles. Whatever I am generating right now
Thanks a lot for any
