🎉Community Raffle - Win $25
Join and Win
Contact with RWALL
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I'm trying to analyse the compliance of an insole under a mapping of pressure and i have to recreate the ground under it so it can lengthen while deforming and blocking the vertical displacement only. I tried to create a rigid wall under it using a node where the ground should be, but during the analysis, only the area where the SPC is applied the movement was block and the rigid wall was completly useless.
I then tried to add a contact between my model and the RWALL but i can't use Contact surface cause it's not a surface. What should i do?
When i added a surface under my model and applied SPCs on it and ran the analysis, my ground started moving...Could it be because it's not applied in the LoadStep i created so the analysis is not taking it into account?
I can share the output file and any other files if needed.
Thanks,
Olivier
1 - 4 of 41
    User: "Beta"
    New Altair Community Member
    Updated by Beta
    Hi,
    As I understand what you described, it is the same like you put a box on the ground and apply force to it, is that correct ??. Try to apply SPC to all nodes on under face of your model and deselect 1st, 2nd, and 4th DOF.  And please share your FEM file if possible.
    User: "Sanjay Nainani_20973"
    Updated by Sanjay Nainani_20973
    Hello,
    Please add the slave nodes of the insole to the RWALL using the add option. I think this should solve your problem.
    Go to Analysis>>rigid walls>>add
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.4a18c6a0741a9aef138b189006555f0d.png
    You can give a distance but better to add the nodes.
    Thankyou
    Altair Employee
    OP
    Hi @Sanjay Nainani,
    I tried to add the nodes but i can only add sets in my version. So i created a set with all the nodes from my component and applied a distance of 1 mm.
    But i get the error 4072 that doesn't work with my analysis in NLGEOM. Do you have any ideas?
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.962af1e76bc518d2a7170e09e20294e6.pngimage.png.0940b2dfd55690eaece4555eacd6d91b.png
    Thanks
    Hello,
    First create a set of all the nodes of the component. Please see there is no node of the rwall in this set.
    Also see that the node set should be created using a entity sets not control cards
    Then keep the distance to zero and then add this set to rwall
    Thankyou
