How to set the shortcuts key for 2D > midmesh > split by two nodes?
1 - 4 of
41
I am first going to recommend you update to a newer(est) version and use the new interface. The sooner you learn that, the better, in my opinion.
You could investigate the required api and map it here
Hi,
I can map 2d>Midmesh>edit edge to a key , but not able to do it for 2d>Midmesh>edit edge>split by two node.
Is there a way to do it.
Thanks!
I would look more at using Custom Ribbons, extensions and Toolbelt in the new interface, as the panel will be depreciated.
https://2022.help.altair.com/2022.1/hwdesktop/hwx/topics/user_interface/ribbon_r.htm?zoom_highlight=custom+ribbon
https://2022.help.altair.com/2022.1/hwdesktop/hwx/topics/user_interface/toolbelt_r.htm?zoom_highlight=toolbelt
https://2022.help.altair.com/2022.1/hwdesktop/hwd/topics/reference/extensions/extensions_r.htm?zoom_highlight=extensions
