🎉Community Raffle - Win $25
Join and Win
Script for moving independent node of Rigids, when changing position of dependent nodes.
During my work, I often change the position of the rigids, but moving an independent node usually requires creating a free node in the newly created hole. Could someone help me write a script that would transfer an independent node based on dependent nodes?
I found out commend:
*rigidlinkupdatecalcinodebycollector
but it change node ID of independent node :(.
1 - 8 of 81
