🎉Community Raffle - Win $25
Join and Win
Script for moving independent node of Rigids, when changing position of dependent nodes.
User: "Michal Kolatowicz_21221"
Altair Community Member
Updated by Michal Kolatowicz_21221
During my work, I often change the position of the rigids, but moving an independent node usually requires creating a free node in the newly created hole. Could someone help me write a script that would transfer an independent node based on dependent nodes?
I found out commend:
*rigidlinkupdatecalcinodebycollector
but it change node ID of independent node :(.
1 - 8 of 81
    User: "Ben Buchanan"
    Altair Employee
    Updated by Ben Buchanan
    Do you want to recalculate the independent node? If so, unless you want to code the equations yourself, I would just query the id of the independent node, use the api you found, and then renumber the node.
    OP
    Yes. I want to recalculate the independent node. How to query for nodes ids adjacent of rigid element? How to query for independent node of rigid element?
    User: "Fred_Juras"
    Altair Employee
    Updated by Fred_Juras
    You can also use the following API to recalculate independent node position automatically:
    *createmark elements 1 1
    *recalculaterigidmainnode 1
    OP
    Where you found this command "*recalculaterigidmainnode". Im looking for a command: on this page :
    Tcl Modify Commands (altair.com)
    because i cant found this command in this page :(
    OP
    Mine interpreter in HyperMesh 2023 doesnt recognize this commend :"*recalculaterigidmainnode 1" It is correct or how to use it?
    User: "Fred_Juras"
    Altair Employee
    Indeed, this *recalculaterigidmainnode API is not yet documented and available only since v2023.1.
    So with v2023, you should use the *rigidlinkupdatecalcinodebycollector command and then renumber the node.
    OP
    I cant find command which get the nodes connected to rigid body. Anyone can help me with that?
    Altair Employee
    This will get you all the nodes from the rigid:
    hm_getvalue elem id=$id dataname=nodes
    This will get you the dependent nodes:
    hm_getvalue elem id=$id dataname=dependentnodes
    And this will get you the independentnode:
    hm_getvalue elem id=$id dataname=independentnode
