🎉Community Raffle - Win $25
Join and Win
CONTACT - cilndric hinge
User: "Alessia"
Altair Community Member
Updated by Alessia
Hi everyone,
I'de like to recreate a realistic cilndric hinge without 0D elems.
The exercise I'm attempting to do is down below. The hinge is on the left corner.image
  • I've created a contact surface
  • I did set Clearance to 0 because of the gap between the red comp and the yellow one.
The PROBLEM is: the yellow comp doesn't slide on the red one. I wanted to permit a rotation on the z-axis but it's like they are stuck together.
Could someone help me?
I'm attaching the HM file and the out one.
Thank you
1 - 4 of 41
    User: "Adriano_Koga"
    Altair Employee
    Accepted Answer
    Updated by Adriano_Koga
    Hi @Alessia
    For your case, you can do 2 ways, depending on your analysis type:
    1) linear (static, modal, etc)
    >> Use SLIDE contact option, and clearance 0.0 >> this will define a frictionless contact that allows sliding/rotation betweeen your contact pairs BUT as it is linear, doesn't consider any separation/closing.
    2) non-linear (static, transient)
    >> Use SLIDE or Static Friction >> this will allow your hinge to rotate AND it will allow you to consider contact closing/opening, leading to a different contatct distribution.
    User: "PaulAltair"
    Altair Employee
    Updated by PaulAltair
    You will need to run 'LGDISP' to see the behavior you expect,
    I modified your fem file, see attached
    User: "Alessia"
    OP
    Updated by Alessia
    Hi @Alessia
    Thank you!
    User: "Alessia"
    OP
    Updated by Alessia
    Thank you!
