🎉Community Raffle - Win $25
Join and Win
implicit modelling
User: "NARAIN KUMAR S_21547"
Altair Community Member
Updated by NARAIN KUMAR S_21547
I recently acquired the educational licence of Altair inspire. But the problem is that I am not be find the implicit mpodelling tab in it. How will I be able to access it.
1 - 9 of 91
    User: "nalbert"
    Altair Employee
    Updated by nalbert
    Hi Narain,
    The Implicit Modelling ribbon is a new addition to Inspire Version 2023, is that the version you are using? If you are using 2023, try going View -> Ribbons -> Make sure 'Implicit Modelling' is selected. Hope that helps!
    OP
    Hi Narain,
    Hi sir,
    I installed the Altair Inspire 2022.3 version from the provided educational license. How to get access to the Altair Inspire 2023 version. Kindly let me know sir.
    User: "nalbert"
    Altair Employee
    Updated by nalbert
    Hi sir,
    I am not very familiar with the educational licenses, could you go to this AltairOne link (https://altairone.com/Marketplace?queryText=inspire&tab=Download&app=Inspire) and download the 2023 version and see if your educational license works for that version?
    OP
    Ok sir, I will check it out
    OP
    Sir, I was able to install the Altair inspire 2023 from the link you provided. Thanks, sir.
    User: "nalbert"
    Altair Employee
    Updated by nalbert
    Glad I could help!
    OP
    Glad I could help!
    Sir, will I be able to use Inspire 2023 on my laptop which has Amd ryzen 5, 16 GB ram, and an integrated Radeon graphics card?
    User: "nalbert"
    Altair Employee
    Accepted Answer
    Updated by nalbert
    I'm attaching a picture of the system requirements for Inspire 2023:
    Your question really depends on the specs of your CPU/GPU and the size/complexity of the models you want to work with. While the recommended ram is 32 GB, you still have more than the minimum required of 8 GB.
    It should also be noted that using Inspire Implicit Modelling has it's own recommended specs where an Nvidia GPU is recommended. AMD GPUs may still work but have not yet been qualified for implicit modelling.
    OP
    Ok sir. Thanks.
