🎉Community Raffle - Win $25
Join and Win
BC are deleted or changed every time I open a model, how can I solve this?
User: "Maialen"
New Altair Community Member
Updated by Maialen
Hi,
I use 2022.2 Altair Hyperworks version and every time I open a model, the BCs I created the last time I edited the file are changed or deleted. Constrains are deleted and forces change the application direction. Thus, I have to define them again.
Does this happen to someone else? How can I fix this?
Thanks
1 - 3 of 31
    User: "Jason_Craanen"
    Altair Employee
    Updated by Jason_Craanen
    Hello,
    No this is not a typical behavior.
    What solver are you using?
    Can you share the model or the setup?
    You might also want to try exporting a solver deck to verify your setup.
    thanks
    jason
    User: "Maialen"
    OP
    Updated by Maialen
    Hi,
    I am using Abaqus solver.
    I am afraid that for security reasons I am not sure I can share the files. But, I just created the BCs from the menu below, shown in the photo.
    As I mentioned, once I close the file, when I open it again, some BCs are deleted or changed.
    First picture, what I originaly created, second, what appears when I open the file again.
    Thanks!
    Altair Employee
    Hi,
    Thanks!
    Since you can't share your model, I would make sure you are looking at the input decks. That is true way to verify. Visually what I see is the difference between legacy loads and the new migrated loads. No loads should be changed or deleted.
    https://help.altair.com/hwdesktop/hwx/topics/pre_processing/entities/loads_r.htm
