🎉Community Raffle - Win $25
Join and Win
not working nodal equivalence
User: "Inkollu harsha Vardhan"
Altair Community Member
Updated by Inkollu harsha Vardhan
in abaqus profile i have 2 coupkins connected with B31 in middle which are seperated initially, (PFA)
when i given nodal equivalence , it shows like equivalenced but still i can see a free node over ends of B31
may i know i to solve this issue
1 - 2 of 21
    User: "Jason_Craanen"
    Altair Employee
    Updated by Jason_Craanen
    I am not able to see the free node from the image.
    You can verify if it is free by using this tool
    can you check here
    OP
    in the image as you can see 4 nodes are selected,
    it is suppose to be 2 nodes if it is connected.
    i have created rigids in current modal and imported B31's from other model
    B31 is placed in perfect position but equivalence is not working.
    even i check free 1D nodes from the above panel you mentioned. it is displayed as 2 nodes are free
