an error of revolute joint
Hello Hao,
For Re volute Joint Definition,
From the error message, you can understand Node 1 and Node 2 in your model , does not have same spatial coordinates.
Try to update the coordinate with NODE 1 or create the temporary (or duplicate) node of NODE 1.
This should work.
Thanks & Warm Regards,
Akshay S Patil
Hi,akshaysp
Thank you for you help,and the picture is very helpful.
Hi Hao Jiang,
In RADIOSS, Altair's leading structural analysis solver for highly non-linear problems , you can easily model joints.
There are many tutorials, webinars,ebooks and other learning materials available on RADIOSS. Please go through https://altairuniversity.com/learning-library/?type=learninglibraryitem&search=&filter_resource_type=&filter_discipline=Nonlinear+Dynamic+(explicit)+%2F+Crash&filter_language=&filter_source= which shows many RADIOSS resources.
For webinars please visit:
hello Hao.
i am facing a same error. can you help me. thanks you so much
Error 20065 (STR+65)
reading joint card no. user ID 5000075 (# 75 in the input order)
Node 1 in rigid body A and node 2 in rigid B are NOT coincident.
Their Coordinates must be adjusted.
*** Error 20065 (STR+65)
reading joint card no. user ID 5000076 (# 76 in the input order)
reading joint card no. user ID 5000077 (# 77 in the input order)
reading joint card no. user ID 5000078 (# 78 in the input order)
Hello Hao,
This should work.
Akshay S Patil
