Hi,I create a revolute joint,but when I compute it by LS-dyna,there is an error,how to solve the problem? Here is the error:reading joint card no. user ID# 110158(# 1 in the input order) *** Error Node 1 in rigid body A and node 2 in rigid B are NOT coincident. Their Coordinates must be adjusted.
