🎉Community Raffle - Win $25
Join and Win
Acoustic simulation : CAABSF/PAASF assignment
User: "Vikrant"
Altair Community Member
Updated by Vikrant
Hello,
I have modelled air around the housing. These structural and fluids are coupled by ACMODL Card. I want to define non-reflecting boundary. for that I have defined PAABSF and referenced to CAABSF. But I dont know how to assign CAABSF to Elements.
Thanks in advance.
1 - 6 of 61
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    The CAABSF element must connect entirely to fluid points on the fluid-structure boundary. Card edit option would help you to assign CAABSF eleements
    User: "Vikrant"
    OP
    Updated by Vikrant
    Thanks Rahul for your Reply.
    But I get some different options.
    <?xml version="1.0" encoding="UTF-8"?>elemedit.thumb.png.8e7b01a614c21b1daf278fb3618f39fb.png
    set  type of element config as quad4 then second option contain will give CAABSF.
    User: "Vikrant"
    OP
    Updated by Vikrant
    Okay, I found it Rahul.
    Thanks a lot.
    User: "Vikrant"
    OP
    Updated by Vikrant
    Thanks a lot.
    Instead applying only on the fluid structure boundary, I have kept elem type as a CAABSF on all fluid Elements.
    Is that fine?
    User: "Vikrant"
    OP
    Updated by Vikrant
    Hi, Rahul,
    I am done with modelling of the fluid structural coupling Problem.
    I have attached file. could you please check it once.
    Bauteil1,2 and platte - structural components
    Air - fluid (At the end non reflecting boundary)
    Please check if PAABSF and CAABSF are correctly defined or not.
    Thanks a lot.
    Regards,
    Vikrant
