Altair RISE
Nominate Yourself Now!
Mesh on an optimized component
User: "mabefa"
Altair Community Member
Updated by mabefa
Hi,
Hi have a disk of a turbine I did an optimization on it and after that I imported the optimized geometry in Solidworks to correct the final geometry. The design space was only the disk so the blade has been left invariated. Then I imported again th new geometry from Solidworks to Hypermesh because I want to to an analysis on the optimized component. I would like to mesh the blade with the same mesh I created for the component when I was doing the pre-processing for the previous optimization.
How can I do it without repeat all the procedure I used for create the mesh firstly?
1 - 4 of 41
