How to get midpointx midpointy value for a crosssection
Hi ,
i need to get cross section values from the HM.
For your reference i attached the image,
from this image we can understand there details of the selected crosssection.
Used code to get the details
Set SecID '320014'
set SectNam [hm_getcollectorname crosssections $SectID] ##This giving the name of the Cross Section ##
But while trying to get the midpointx ,midpointy ,midpointz its always giving 0
set MidX [hm_getentityvalue crosssections $SectID midpointx 0]
set MidY [hm_getentityvalue crosssections $SectID midpointy 0]
set MidZ [hm_getentityvalue crosssections $SectID midpointz 0]
set MidNode [hm_getentityvalue crosssections $SectID basenode.id 0]
set NormalX [hm_getentityvalue crosssections $SectID normalx 0]
set NormalY [hm_getentityvalue crosssections $SectID normaly 0]
set NormalZ [hm_getentityvalue crosssections $SectID normalz 0]
for this i getting zero for all.
Kindly help me to solve this issue
Thanks in Advance
Regards
Suresh Kumar V
Hi Tinh,
i need to change the nodes of the cross section i used this code to change the nodes but its not changing.
#After Importing the Sections
#getting the sections in a list
*createmark crosssections 1 'all'
set sec_ID_List [hm_getmark crosssections 1]
#for createing the cross section need to select node first
foreach secID $sec_ID_List {
#giving user to select the N1
*createmarkpanel nodes 1 'Select the Orgin Node'
set Or_N1 [hm_getmark nodes 1]
*createmarkpanel nodes 1 'Select the Axis Node N2'
set Ax_N2 [hm_getmark nodes 1]
*createmarkpanel nodes 1 'Select the Axis Node N3'
set Ax_N3 [hm_getmark nodes 1]
#setting the selected nodes
puts 'secID = $secID'
puts 'Or_N1=$Or_N1'
puts 'Ax_N2 = $Ax_N2'
puts 'Ax_N3 = $Ax_N3'
*setvalue crosssections id=$secID Axis_Origin_Node_N1= { nodes $Or_N1 }
*setvalue crosssections id=$secID Axis_Node_N2= { nodes $Ax_N2 }
*setvalue crosssections id=$secID Axis_Node_N3= { nodes $Ax_N3 }
Kindly help me to change the data of the crosssection like
Three Nodes N1,N2,N3 and grshel_ID
i attached image for your reference
Thanks & Regards
Suresh Kumar V
Hi,
crosssections do not have data names as midpointx, midpointy, midpointz
for normal, you have to input data names 'Normal_x' 'Normal_y' 'Normal_z'
refer to help document about data names of crosssections
