How to get midpointx midpointy value for a crosssection
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hi ,
i need to get cross section values from the HM.
<?xml version="1.0" encoding="UTF-8"?>59b7d4451253c_Image1.thumb.PNG.f408c7910c6f737f3ca5a725d362d108.PNG
For your reference i attached the image,
from this image we can understand there details of the selected crosssection.
Used code to get the details
Set SecID '320014'
set SectNam [hm_getcollectorname crosssections $SectID]  ##This giving the  name of the Cross Section ##
But while trying to get the midpointx ,midpointy ,midpointz its always giving 0
            set MidX [hm_getentityvalue crosssections $SectID midpointx 0]
            set MidY [hm_getentityvalue crosssections $SectID midpointy 0]
            set MidZ [hm_getentityvalue crosssections $SectID midpointz 0]
            set MidNode [hm_getentityvalue crosssections $SectID basenode.id 0]
            set NormalX [hm_getentityvalue crosssections $SectID normalx 0]
            set NormalY [hm_getentityvalue crosssections $SectID normaly 0]
            set NormalZ [hm_getentityvalue crosssections $SectID normalz 0]
for this i getting zero for all.
Kindly help me to solve this issue
Thanks in Advance
Regards
Suresh Kumar V
Welcome!
Answers
  • tinh
    tinh Altair Community Member
    edited September 2017
    Hi,
    crosssections do not have data names as midpointx, midpointy, midpointz
    for normal, you have to input data names 'Normal_x' 'Normal_y' 'Normal_z'
    refer to help document about data names of crosssections
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi tinh,
    there is no datanames as crosssections but i didnt get entity value using groups.
    how can i get details for cross section using getentityvalue
    Kindly help me to find out this issue.
    Thanks & Regards
    Suresh Kumar V
  • tinh
    What are details that you need?
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Hi Tinh,
    i need to change the nodes of the cross section i used this code to change the nodes but its not changing.
        #After Importing the Sections
        #getting the sections in a list
        *createmark crosssections 1 'all'
        set sec_ID_List [hm_getmark crosssections 1]
        #for createing the cross section need to select node first
        foreach secID $sec_ID_List {
            #giving user to select the N1
            *createmarkpanel nodes 1 'Select the Orgin Node'
            set Or_N1 [hm_getmark nodes 1]
            *createmarkpanel nodes 1 'Select the Axis Node N2'
            set Ax_N2 [hm_getmark nodes 1]
            *createmarkpanel nodes 1 'Select the Axis Node N3'
            set Ax_N3 [hm_getmark nodes 1]
            #setting the selected nodes
            puts 'secID = $secID'
            puts 'Or_N1=$Or_N1'
            puts 'Ax_N2 = $Ax_N2'
            puts 'Ax_N3 = $Ax_N3'
            *setvalue crosssections id=$secID Axis_Origin_Node_N1= { nodes $Or_N1 }
            *setvalue crosssections id=$secID Axis_Node_N2= { nodes $Ax_N2 }
            *setvalue crosssections id=$secID Axis_Node_N3= { nodes $Ax_N3 }
    Kindly help me to change the data of the crosssection like
    Three Nodes N1,N2,N3 and grshel_ID
    i attached image for your reference
    <?xml version="1.0" encoding="UTF-8"?>59b935b3c34e8_IssueImage.thumb.PNG.4d8af8154cf49ed33ed80dbd43658efe.PNG
    Thanks & Regards
    Suresh Kumar V
  • tinh
    Please try changing {nodes $Or_N1} by 'nodes $Or_N1'
    And also for n2, n3
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Thanks a lot tinh , its working
    Regards
    Suresh
Welcome!
Welcome!
